- Joined
- 14 Oct 2019
- Messages
- 2
- Reaction score
- 0
- Country
Hello everyone,
We have recently moved into a 1950’s build house with an integrated garage that has a very cold bedroom above it. I have checked the loftspace which has an old loft conversion but has minimal insulation around the pitched part of roof under which the bedroom sits. I am planning on topping this up.
The whole house needed a new heating system, so I have been in the process of replacing all the central heating rads/pipes/boiler, as the new boiler sits in the garage I was asked by the plumber to remove the asbestos ceiling in the garage which is now gone so he could route the pipework through without the dangers of disturbing the asbestos.
Since the ceiling has been taken down I have taken it upon myself to insulate the space between the bedroom my 1 year old sleeps in and the garage below, after lots and lots of research I have decided to use foil faced PIR board 100mm (Ballytherm brand) from the garage ceiling butted up against the floorboards between the joists. There are some areas between the joists that contain cables/pipes that I will be covering with conduit and due to the awkward ness of the space between the joists I will use a rockwool type of insulation. I am then planning to board up with pink fireboard.
My question is, is this the correct way to go about it am I leaving myself open to condensation issues, I’ve been reading about vapour layers and whether I need one. Any help would be appreciated,
