Okay, Im not a total idiot but still...
I have a large double garage which already has a partition down the middle - other than that is single brick, concrete floor construction with two single-glazed windows.
Building a stud wall/adding buttons to the walls is a piece of cake. Where I'm a little confused about what kind of insulation I need and how best to apply it to minimize dampness.
I've heard some say I need an air gap between the single brick wall and insulation, while others have said a simply damp-proof sheet/membrane between the wall and insulation will do the trick (with no real gap). On top of either id be installing plasterboard.
As well as this Id like to insulate the floor - my thinking is to add more buttons to the floor, add insulation, and OSB on top.
the space would then be heated with either electric rads, or a diesel heater
any help would be appresiated
