I have a detached brick single skin garage (no dpm), on the whole it's pretty dry save some occasional 5mm damp marks where the brick meets the floor, where I have painted the inside the paint is mostly still there save occasional bits over the mortar (planning on treating the outside with water repellant stuff). I am looking to insulate it to use it as an occasional office and gym. It's a flat roof which is being redone now. My plan was:
1. Leave the main garage door in place, build a stud wall with 50mm kingspan behind it (wife concerned about removing the door for some reason).
2. Stud the rest out with 50mm studs and kingspan as well
3. Membrane round the whole thing
4. 12mm Ply round walls (to attach pallet wood)
5. Attaching recycled wooden pallet wood round the entire wall.
6. Floor kingspan, vapour barrier then laminate (uninsulated slab, always seems dry).
7. LED Lighting, 3 x 600 watt convection heaters
The membrane is because the wood will not likely be enough of a barrier for warm air to potentially get to cold brick.
Am I asking for trouble by cladding in wood? Is it a fire hazard / death trap?
Graham
Graham
