I'm redecorating/improving my utility room in the back of the garage.
The back wall is approx 2.5m long and is only single brick. There is quite a large dg window in the wall.
I want to insulate this so I'm going to baton the wall with timber and plaster board over.
What would be suitable to insulate the gap? Should there be a bit of an air gap? I'm guessing celotex or similar would be the best bet, but could something like rockwool be used as I have some left over from the loft.
For the plaster board is normal 12mm plaster board OK? Or should I use foil backed or something like that?
I've read a bit about Thermaline - which looks promising but I've struggled to find how to fix it in my situation.
Can you just stick it to the brick wall like you would with plasterboard? Is any other prep needed?
