Insulating a steel framed workshop
4 Sep 2007
Shropshire
I have a 3 bay steel framed shed with a fibre cement roof,the end bay is 20 foot x 12 x 12 high which has steel cladding on 2 sides and feather edge boarding on the other 2,also the floor is stone .in the winter it gets very damp and cold in there so i need to insulate it.
What do I use and how do I go about it?
Rockwool behind some plywood or something will help, but it'll still be damn cold and damp.
Best bet is probably a space heater and a bottle of propane :LOL:
As neo says adding a vapor shield between the walls and the rockwool.
Pete
Rip off all the current sheeting and Kingspan it.
Job done.
Thanks for your help,Rockwool is that similar to fibreglass insulation on a roll.Kingspan is made just down the road here,
Vapor shield ,is that on the outside to keep the wet out,if i use kingspan do i need a breathable membraine on the inside to prevent warm air /water vapour passing through. : :
