Rigid PIR/PUR board is roughly twice as good as quilt insulation.
So same insulation value for 1/2 the thickness or twice as efficient for the same thickness
For a garage partition, you need 100mm of the xtratherm. No need for foil backed board with this insulation, nor in this situation (ie internal partition). Nor fire rated plasterboard.
