Insulating an existing room in roof.
15 Oct 2023
Hi, I would be grateful for any thoughts on how to improve the insulation in 2 RIR bedrooms.
They are in a dormer bungalow built early 50's we think. The dwarf walls are actually built of approx. brick sized cinder blocks and there is loft access all around the loft side of the walls. There is no access into the loft space at present above the bedroom ceilings.
My idea's are to remove the ceiling & skeiling plaster boards, install insulation slabs between the rafters, on the skeiling. Make an access into the loft space above the non sloping ceiling and use st rockwool 100mm + 170mm. I would also like to use use 32 mm insulated plasterboard to replace the existing plaster board giving a insulation combination of the between rafter insulation and the insulation on the back of the new plasterboard.
Does this seem a sensible approach and are there any complications to watch out for?
Finally what's the best way to insulation the cinder block dwarf wall from inside the loft space, I dont want to make the room space smaller by insulating inside the room.
Thanks in anticipation of your contributions.
Rgds
JLS
Any insulation will be an improvement but you will have to lose room space to bring it up to modern standards
Blup
