Insulating an internal wall
25 Jun 2006
Hi All,
Could anyone tell me if an internal (studded wall with plasterboard finish) can be insulated by pumping foam in through holes on the room side? I believe that in the USA they have systems that are a DIY application. I really would apreciate any advice
Michael :(
This is the pumps you mean
http://www.spray-insulation.co.uk/product range.htm
but they are used to spray a cavity as you look at it before covering.
A bit like how you spray a car.
I would think a worry of blowing your plaster board if you can't see where you are putting it.
Also have you got electrical cables in the cavity im sure some where theres info regarding the melting of the wire covers if contacted by certain chemicals.
Other option is replace plater board with insulated plaster boards
http://www.lafargeplasterboard.co.uk/products/concepts/thermal1.htm
im no professional so i am sure someone will be along with more info
don't go down the 'pump it in' route, use insulation backed plasterboards as said previous.
