We recently moved into a 1930s house, where the previous owner has wrapped the entire area of the loft in plastic sheeting.
Apart from being rather odd, I'm worried about condensation.
I had thought it was a DIY attempt at insulating/weather-proofing in response to missing roof tiles.
However, having had a roofer in to check the general condition, he thinks that it was put up to stop stored items in the loft being covered in dust from the lime mortar securing the tiles (the roof is un-felted).
I want to remove the plastic sheeting, and insulate the loft (it is currently 'boarded' with old doors etc. and there doesn't appear to be much underneath), but still have it useable for storage.
I've not measured, but I'm assuming the joists won't be deep enough for me to lay rolled insulation to a sufficient depth/U-value and still lay boards over the top.
Seeing as I'm going to have to put some kind of barrier (something like a breathable membrane) up to prevent the mortar covering everything in dust, should I add additional insulation between the rafters?
If so, what is the best option? I'm presuming I need to take care to keep a gap between the insulation material and the loose mortar.
