Hi all, grateful of your views.
I’ve a Victorian house with downstairs bathroom with a concrete floor - very cold!
Want to insulate with rigid celotex or similar over a DPM.
We have a Victorian style bath ( lightweight acrylic not cast iron) on 4 legs, each leg load is on about a sq inch of floor.
My question is, will floating a p5 chipboard floor straight over the celotex be up to the job ( so a proper floating floor) or given the weight on such a small area, should I batten out the floor at something like 300-400 mm centres ( which will give some cold bridging) and celotex in between.
Floor will be 10mm tile on 6mm backer board on 22mm thick chipboard. Just don’t want the bath to sink!
(Bath waste will need to go straight down into the floor, so planning on carving a small trench into the celotex for pipe work with 25mm clearance around pipes to account for any slight movement in floating floor).
Many thanks, Jason
Many thanks, Jason
