Hi all, I've been reading posts on this site for a while but this is my first message..
Our house is a 3-bed 1930s south-east-london semi with solid walls and we get pretty bad mould on the inside of the first floor bay window. (similar on the ground floor, though not quite as bad)
The bay wall in question is about 2.5m wide by about 1m high. It sits beneath new-ish UPVC double glazing without trickle vents. And had a small-ish radiator in the middle of it.
I've taken off the radiator and I reckon without moving the pipes to it I've got about 15-18mm to add some insualtion to the wall behind the radiator before refitting and redecorating it.
The aim of this bit of work would be purely to stop further condensation & mould on the wall rather than make much of a difference to total house insulation.
What I've got in mind is to put 10mm square vertical battens on the wall, some kind of insulating material - TBC (just air maybe.. recommendations welcome!) - between the battens, vapour barrier sheet on top of that (sealed on all sides), 5 mm ply on top of that then a plaster skim, paint and refit radiator.
What do people think? Will this 1. be warm enough to reduce condensation (and therefore mould) and 2. be an adequate design to prevent internal condensation that causes problems that I can't see?
Cheers,
Tom
Cheers,
Tom
