We live in an old detached victorian house - which has solid walls (no cavity).
Currently sorting plumping out and then redecorating so I thought i'd be a good time to insulate the bedroom outside walls - something I'd been thinking about lately (especially after the last winter we just had).
Would welcome any advice or experience of someone who's done this?
At first I wanted to just dot & dab either K17 kingspan or Celorex PL4025 (25mm of insulation + 12.5mm plasterboard) onto the existing plasterwork, and then skim over (on the 2 outside walls in each bedroom).
The guy I've got in mind says that in his experience the shiny surface of the insulated boards doesn't bond/stick very well. So instead suggested to batten the wall and then cut kingspan insulation and pack inbetween the battens tight up against the wall. And then to fix regular plasterboard over and skim.
My concern is - what should be done about the vapour barrier? As the insulated board (K17/PL4025) has a vapour barried built in. But the builders approach above i'm guessing won't.
In case anyone is wondering - I don't really have much space to batten and create a cavity (as another alternative solution) as it'd mean re-doing a lot of the radiator pipework.
Many Thanks,
Many Thanks,
