Inquiry about completing a newly constructed cathedral/vaulted roof.
Rafters with a depth of 220mm
My current plan consists of the following:
- 50mm air gap (below the roof membrane)
- 120mm rigid board insulation
- 50mm gap/service void
- Plasterboard
- Skim coat
Questions:
*Is it acceptable to maintain the 50mm gap/service void above the plasterboard, or does the insulation need to be flush against the insulation for optimal efficiency? The reason for the 50mm gap/service void before the plasterboard is to facilitate easier installation of electrical wiring and spotlights. Any thoughts on this?
*Which rigid board would be recommend as the best option for this project?
Many thanks
- Plasterboard
- Skim coat
Questions:
Many thanks
