I'm currently doing the insulation for newly built kitchen extension that has a pitched roof. This is being done to building regs - 100mm celotex (GA4100) between the (150mm) rafters, coming flush to the internal face of the rafters, then another 50mm + 12.5mm plasterboard will go over the top (I'm using PL4050 for this).
I've friction fitted the 100mm layer between the rafters and I'm foil taping where celotex edges meet each other. Do I also need to foil tape over where the celotex meets the rafter? How thorough does this need to be given the PL4050 is going on top? Should it cover the rafters entirely so its all foil and no wood showing?
Thanks...
Thanks...
