Im considering insulating a wall internally as this room gets very cold as soon as the heating is turned off. Its a downstairs living room, and my plan is to insulate the exterior wall. We had insulation blown into the cavity walls within the house, and insulated the suspended floor to reduce draught, however it is still cold in this one room. When i asked my builder about this, he recommended to 'dot and dab' 50mm EPS 'jablite' insulation to the wall, then plasterboard and skim. When i asked can we do the same with celotex, he said its difficult to stick that on the wall.
My questions are:
Is EPS insulation safe to use internally?
Is it possible to dot and dab celotex onto a wall?
What method would you guys recommend for insulating this wall?
Many thanks
My questions are:
Many thanks
