I know there are a few threads on this but most appear to relate to full conversions to habitable living areas etc. My situation is a little different. I want to insulate garage for the purpose of a workshop (woodwork mainly);
I currently have a standard single brick garage that is approx 3.1m(W) x 6m(L) x 2.31m(H) internal dimensions, not including the 4 double brick pillars. It is flat roofed. The roof appears to be OSB with the felt stuff on top (don't know name). The floor is concrete. I cannot tell if it has a DPM. I doubt it. The garage itself is built on a sloping garden, so the back of the garage is quite high up compared to driveway point. There are 2 windows (1 at back wall, and 1 on side), up and over garage door. Currently no side door as previous owner blocked up, but will be easy enough to open up again.
I want to be able to use the garage as a workshop and not be freezing my balls off lol. I would also love it so that the garage was relativity not so damp! I have no idea on cost right now, so if anyone has a wide ranging ballpark figure of costs would be great.
Some questions;
Flooring
1) What is the best option for insulation, and which would be cheapest or less hassle? Reading around, looks like I would need to dig out floor... Maybe I have to with the limitation on height to celiling?
2) If I do dig out and insulate, is it easier to put floating floor or just get it filled again with concrete etc?
Walls
3) What wall thickness of insuatlion can I get away with to maximise size? As its not "habitable" I don't need to condone to house regs ??
4) I see you can get plasterboard with insulation attached. Any good or waste of money?
5) What would be efficent and cheap way to finish walls. Could I get away with OSB?
6) Garage door. I really have no idea how I go about insulating this? Do I need to look at a new door? Perhaps 2 hinges?
7) What about blocking up the garage door wall. Is this a bad idea? Can I even do this? Will this effect house re-sale value, or anything? Does this effect mortgage even? Not planning on moving anytime soon. Looking to stay for a very long time.
Celing
8) Guessing insulation between joists. Recommended product / thickness? I need to leave gap at top??
9) What about ventilation?
Other
10) Would it be cheaper and easier to install to just use conduit for all electrical cables etc for lighting and sockets?
11) Planning permission, from what I have read, I do not need any planning permission generally for this type of work, do I need to have building control involved??
12) Lastly, if you have any good websites/documents on this topic, please share!
Thats all I can think off for now. I probably have typed far too much and now most people will ignore this thread. Ahh, hope not.
Any comments are highly appreciated!
Thanks !
Some questions;
Flooring
Walls
Celing
Other
Thanks !
