I understand this may be an impossible question to answer but here goes....
Sick to death of the misses drying out our clothes in the house as it makes the walls cry and can see the breeze blocks sometimes :O
So I thouyght we'd invest in a tumble dryer, enter problem 1.
We were after a small condensor tumble dryer to fit under a certain/only space in our kitchen, but problem is there only normal size and can only get a small vented (no good) at it's on the wrong side of the house (semi)
So I was thinking of putting it in our small shed, but was going to use some insulation boards (celoex 50mm?) inside the shed and hopefully give it some warmth.
This is because it looks like tumble dryers require a min temperature because of forst, but we'd be getting a vented one but still looks like they need an ambient of atleast 2oC.
Without knowing the temps in winter, by guessing would you say the insulation boards will do any good? or is it simply not going to be enough to keep it atleast 2oC.
Obviously if it's low minus numbers it won't help at all, but if outside is say -1, -2 would the boards be enough to keep it to 2oC?
