I am going to be boarding my loft out, before I do this I want to insulate in between the joists. The joist are only 75mm thick, what is a alternative insulation to use apart from lagging as this would not be adequate due to the joist size and boarding ?
Would 75mm boards of polystyrene be ok cut to fit snug between the joist then board be ok ?
I remember seeing one on a diy tv program where you pour it in the joists, can anyone tell me what this insulation is called.
thanks in advance
thanks in advance
