Hiya
i have done some searching and reading and really just want to confirm a few things
we are redecorating a bedroom in our house and we are going to get it re-skimmed - so whilst im making a mess i thought i would insulate one of the walls ( and the fact that the room is bloody freezing !! )
so ....
Its a 1970 house with a dorma built in prob 1975 and i dont think they heard of insulation in those days
we have recently had the dorma reclad in plastic and insualted but its still not retaining any heat
so is it worth while studding out one of the walls and insulating it ?? im thinking that something is better than nothing - but on the flip side of the coin - if im only doing one wall - will the heat just escape from somewhere else ( like thru the roof )
the wall in question is the wall between me and the neighbour - so in theory its half wall and half dorma ( if that makes sense )
if you place your hand on the wall in different parts you can feel the difference in temperate as to what is brick and what is the dorma
you can also feel a difference in temperature with the ceiling of the dorma ( outside ) and the part of the ceiling which is effectively the loft ( which has 200mm of insulation in it )
the plan is ( so correct me if im wrong ! )
1 - leave the plaster on the wall ( surely it acts as extra insulation )
2 - screw 2*2 battons to the wall in a frame
3 - fill the space with 50mm polystrene sheets
4 - work out where i want extra plug sockets and put some 35-40mm tubing in place so its easy to run the new cables
5 - screw plasterboard to the front
6 - phone plaster and get it all reskimmed
im also tempted to add a 2*2 frame and do the same thing to the ceiling of the dorma ( the ceiling is split by a perlin so its easy to work out what is dorma ceiling and what is directly under the loft )
does this sound about right - or i have i missed anything ( damp barriers etc..)
if all this is a workable solution and fixes the problem then i might be tempted to do the other wall so that the dorma side both have internal insulation ( i will only loose 6-7 inch off the width of the room and that not a problem aslong as its warm ! )
sorry about the long post - but i would rather do it right the first time !!
thanks
Stu
so ....
thanks
Stu
