I have recently moved to a new house where some work has been carried out in the loft. This includes moving and reinforcing the roof supports, strengthening the floor joists, flooring and fitting a velux window. Infact pretty much a complete loft conversion except there is no staircase to go up so access is via a ladder (space in the rest of th ehouse is at a premium and adding the staircase would mean pretty much losing one of the upstairs rooms - of which there are only two).
I have building regulations for the work carried out 10 years ago so it has all been done properly.
I would like to use the loft as an occasional studio. However there is no insulation and the roofing felt is fully exposed.
What i the best way to insulate the space to keep it warm in winter and cool in summer?
What are the best materials to use?
I am thinking insulate between the roof rafters leaving a 50mm air gap between the underside of the roof and the insulation, then plasterboarding over the lot. Is this correct? What is the best way to ensure there is a 50mm air gap between the underside of the roof and the insulation? Do I have to use solid insulation sheeting like Celetex or kingspan? If so which one, how thick? Or can i do it with normal rolls of loft insulation? What is cheapest?
Is it possible to buy the sheet insulation cut to the correct width to fit between the rafters? or plasterboard sheets that are long and narrow so I can get them through the loft hatch.
All advice gratefully received!!!
