Insulating Shed
30 Jan 2014
Essex
I'm not entirely sure if this is the right section, but I'm looking to insulate my shed to store some tools in it. It's built using 44x44mm framing but most insulation seems to be 25 or 50mm. Will the 25mm work? Or will having a gap between it and the board I'll put over the top reduce or eliminate it's effect?
Or could I squeeze 50mm in there? Will it compress by 6mm? I'm only planning on using a cheap polystyrene board.
And, how would I insulate the roof and floor? Do I need to?
outside cladding 12-25mm space breathable membrane insulation internal finnish
Sorry, I'm a bit confused by your reply.
Do you mean, it'll be fine to have the 25mm gap between the insulation and the internal board?
between outside cladding and breathable membrane you have a 12-25mm gap
between breathable membrane and internal cladding you have your insulation
you can add batons to the timbers you give you additional space for thicker insulation and or extra air gap
its better you have as near to 25mm air gap as possible to avoid the insulation pushing the membrane into the air gap or touch the cladding
