Insulating solid brick wall
15 Apr 2005
Yorkshire
I have just bought a house with solid double brick outer walls. Its a semi.
In the HIP it states about this being very inefficient and there will be no insulation etc.
So I'm just speculating about insulating it. What are the options? I know there are plasterboard products available with insulation on the back, and I know about building stud walls - but the thing is, its only a small house and I dont want to loose any more space inside.
Is there any options externally? Next door (attached) is rendered - does this add any insulating properties? Are there renders that do?
The house has had a damp couse injected at some point (plastic bungs outside).
Not yet - there were delays associated with the shall-we/shan't-we on-again/off-again extension, and then I had to have a spell in intensive care with a nurse rubbing me down with a damp copy of Approved Document L when I got the quotes.
:cry:
In a month or two, we hope.
In that case, when you feel you have some conclusions, I think a lot of people would be interested if you felt you wanted to post them.
Yes, I would too ban.
It looks to go on pretty thick this stuff - then again i suppose it has to. Just a little worried about it making the house look daft, and the side of the house is actually facing the pavement. There is a virgin TV cabinet against the house wall there too. Am I right in thinking external insulation here would be impossible due to it facing a pavement, and technically not being my land.
Whilst this is true Steve you should really treat any advice in a HIP with a pinch of salt. The people that write these reports are not building professionals and, on the whole, have very little knowledge of construction techniques. Whilst you've not detailed the exact construction of your property, I would hazard a guess that a single, working lad of your age would not get a viable ROI on external insulation in your case.
I know what you mean about them not being written by professionals - theres bits in this report that I can pick out as being wrong, even not being a building professional myself. Must think we're all daft. The drainage stuff is interesting though - maps etc.
