Insulating under flat roof
23 Jan 2003
Hi, I have converted part of garage into downstairs cloakroom. Need advice on insulating before putting plasterboard ceiling on. I have levelled out the sloping joists with thin strips of wood but do not know what type/thickness of insulation to use. The joists are 5 inch. Advice please
Hi Glyn1959
I was just about to post this question, so I'll jump in here for an answer.
My converted room is a kitchen with concrete flat roof, wondering if need vent or something to remove/prevent moisture?
Nowtaboutnowt, please raise your own post. Your roof is quite different and you will confuse the issue. Feel free to read forum Rules on Hijacking.
MOD RUPERT
What did you describe in the proposal you sent to your BCO before starting work? Find out, then do that.
