Our house features a floor construction that includes a fairly level concrete slab across which 3"x3" joists are laid (shimmed as required to achieve levelling) and then with floorboards nailed down across these joists.
Over the years, a lot of the shimms have worked loose and the floor creaks and groan as you walk across it. Also, a draft blows through the gaps between the floorboards on windy days making the house impossible to heat.
If I remove the floorbaords, re-shim the joists and lay new flooring would there be a problem with also adding insulation between the joists (essentially insulating the new boards from the cold concrete below) or should I leave the channels between the joists open for under floor ventilation?
If I do add insulation, what type would be best?
Cheers,
iep
Cheers,
iep
