Hi
We are in the midst of insulating between the joists our timber floor in our 1930's house.
We have lifted the floorboards and have fitted a breather membrane over and between the joists that is supporting 100ml earthwool blanket insulation.There is a very good air flow from the air brick and a good amount of space underneath.
The joists run parallel to the external wall and at right angles to the internal walls. However there is a gap of between 1-2 inches between the end of the joist and the brick internal wall.
We intend to put a VCL over the top, adhere to the walls and then replace our original square edged boards. We will silicon gaps.
My question is do we fill the gaps at the end of the joists with insulation? Would it cause the ends of the joists to rot?
Cheers
A
Cheers
A
