Hi
I would like some advice on a roof i am currently insulating
I have a pitched roof barn/workshop which i am trying to insulate
The roof is constructed with 6" deep rafters , the rafters are then boarded externally with 18mm plywood which is covered with Tyvek Supro breather membrane and then directly covered with plastic slates onto the tyvek with fixings into the plywood.
i initially decided to fill the voids between rafters with 140mm celotex and then board the inside out with 12mm plywood
The barn is used as non residential and purely for storage but i decided to insulate to keep it very dry so i could store books vehicles and machinery etc and also occasionally working in there without having to heat it significantly. my plan is to have a small dessicant dehumidifer running in there just to keep the atmosphere dry for papers / fabrics etc..
I am looking at whether i will have any condensation issues
Do i need to add a vapour barrier - ie polythene sheet before fitting the internal plywood sheeting ? or would taping the joists with some form of tape to bridge the celotex over the joists do the same. Or could this trap moisture into the roof timbers and boarding
i am presuming any moisture will permeate outwards through the tyvek supro and out through the very small gaps between the slates.
My only other option is to extend the rafters down by 50 mm and install the 140mm celotex with a 50 mm gap between the top of the celotex and the underside of the outer ply and then ventilate through the soffitts and the ridge.
This cold roof ventilation option is obviously more involved with more work and i would prefer not to go this route - not sure if introducing moist air in this void in the winter months will give me other problems.
I understand that my original proposal is not technically a warm roof as i dont have insulation over the rafters and under the exterior boarding.
just trying to assess any condensation risk and minimise any roof timber rot and also maximise the insulation i can achieve.
I would like to add minimal heating at a later date for occasional working in the barn so this needs to be taken into consideration
The barn is a completely open area - vaulted ceiling with an open mezzanine floor at one end -
I would appreciate any advice from roofing / building experts on here.
thank you
thank you
