Hi All
Quick question, I have a bay window in a second floor bedroom with a lower ceiling to the main one. The bay is about 2.0m x 0.6m, the plaster had gone in that section of the bedroom so I took the old plaster down. I will put a vapour barrier on, board it and then plaster. The void is built of 3" x 2"s and is not insulated (it is a flat roof covered in led).
I am thinking of insulating it but there is no airflow, it's a sealed void, I know that normally you need airflow above the insulation but will this matter in such a small space?
Thinking of using 50mm of Celotex, mineral wool or polystyrene.
Any comments or advice would be appreciated.
