Building a timber frame with 50mm PIR insulation boards in between.
Should these be flush against the front of the stud work or set back slightly?
I'm thinking if I set them back I can fill what gaps I have with expanding foam more easily, but might this then cause cold bridging in the gap between insulation and plaster board?
