I've just had a roof re-slated (in N France), and the builders have now finished insulating the underside with knauf paper-backed insulation. This has been stuffed tight inbetween the rafters and is touching the breathable membrane. The brown paper backing is facing into the house and all joints have been taped. They have told me this method is ok, but I'm sure there should be an air gap between the insulation and the membrane? There are also 4 vents on each side, and the roof is just under 200m2
I have the folowing build,
slate
20mm batten
20mm batten along rafter length
breathable membrane
7.5 cm rafter
10 cm knauf insulation
Can anyone confirm who is right?
thank-you,
Chris
slate
20mm batten
breathable membrane
7.5 cm rafter
thank-you,
Chris
