Hi all. I have recently removed all of the internal plasterboard underneath our upstairs bay window. Since the double glazing was fitted several years ago there was a little bit of settlement and cracks appeared where the wall ended and the wooden bay framework started. I have now fitted heavy duty straps to stop any further outward movement (although it may not have moved any further anyway, I wanted to be sure.)
Now that I have this void and have replaced / strengthened the timber framework, I am wondering what sort of insulation to use, if any? Obviously the outer membrane is not air tight and I imagine the air circulation in the void would dry it out should any water penetrate the outer tiles and membrane. Would it be best to leave this as a void or pack it out with something? If so would I risk damp being transferred to the internal plasterboard if water did penetrate the outside?
I have attached a picture.
Thanks for all advice.
