Insulation over boards
22 Feb 2006
My loft is boarded down the centre, which corresponds to being above the long-ish hallway. Here it has, maybe, 50-75mm insulation under the board. Would laying a couple of rolls on top of the boarding help with heat loss? I need it boarded, so don't want to pull it up.
The air gap between the insulation will effect the insulation efficiency.
You will need to get the floor up and pack out with insulation.
What's stopping you? Not normally a problem to lift a floor
