Our conservatory dwarf wall has been built of concrete blocks laid flat, therefore no cavity. Outside is rendered and harled. What is the best thing to do with this dwarf wall internally. I want to loose as little internal space as possible. Of course I want to retain heat as we are having radiators installed.
Must I create a full internal timer frame construction?
Would it be senseless to batten the blocks and use just thermal plasterboard with a vapour barrier. Would external moisture infiltrate this and cause problems?
Any advice in achieving a warm dry wall, taking up as little space as possible, would be much appreciated.
