Insulation Question (Warm Roof)
10 May 2022
Hi, I have a question regarding regarding a a warm roof and adding some additional insulation underneath.
We have upstairs dormer extension which is used a a home office (small room ca. 2m x 2m). The roof height is very low (probably 1.9m) so I have taken the plasterboard off to get the height between the rafters.
I was going to just plasterboard under the deck (using battens so i wouldn't drill in to the deck). However, I might lay some rigid insulation tight against the ceiling and put the plasterboard over that. I would tape the insulation (and fill gaps) so it would be air tight so might be a vapour layer.
Would I have any issues with this in terms of condensation or should I just leave as is. I read somewhere if the insulation below the deck is less than above it should be OK.
Any thoughts appreciated.
I don't understand what's happening to the rafters/joists if you are planning to board directly under the deck.
There are joists on the ceiling. I've taken off the plasterboard to expose them.
There is now a 170mm gap from bottom of joist to deck above.
Plan is to add insulation (25/50mm) and plasterboard over the insulation. This will be held in place with battens which I will attach to the joists. This will give the room a feeling of more space as there will be another 100mm head room between the joists.
Hope the above makes sense.
SO exposed timber joists? Are you actually gaining any useable space by doing that? You will still have to lower your head to travel in the room?
Ceiling is already off. Yeah it looks a lot better. Bottom of joist is 1.98 (gained 12mm from removing plasterboard) so no lowering your head. Will paint the joists and make a feature of them.
Any thoughts on the insulation?
