- Joined
- 15 Mar 2017
- Messages
- 79
- Reaction score
- 1
- Country
Hi All,
Just a quick questions with regards to some insulation. I have had my foundations laid for my self build conservatory. I am now reading about the insulation under the concrete slab, and also the cavity insulation. Do i need 100mm insulation beneath the concrete floor slab? Or could i use 75mm or 50mm instead? Can anyone help with which to use, Jablite seems cheapest but is this good enough for what i need?
I am thinking about using a 50mm cavity for my walls so will use a 50mm cavity insulation, can i use the rock wool type for this or is it best to use the sheet type ones?
I am building under permitted development so don't need to build to regs if this helps with your recommendations?
Sorry for all the questions but i am trying to build to a budget
John
John
