Insulation spec for under rafters
27 Sep 2007
Lancashire
Hi
Re-surrecting an unfinished project in an 1820s farmhouse where i submitted a Building Notice in Sept 2007 for a loft conversion to make it into two habitable rooms.
How can i establish the spec for insulating beneath the rafters ?
rafters only 3" x 2" so i will need 50mm air gap to start with,
option 1, can i run GEN-x Insulation blanket straight onto rafters then batten then plasterboard ?
option 2, batten the rafters to make them deeper to fit sheet insulation boards 50mm thk ? or rockwool ? then blanket, then batten then plasterboard ?
Please Advise
How much headroom do you have?
I’d do a full layer of 100mm Celotex under the lot.
