I have an application where there is a block of flats with four flats which has an intercom system. There is an alleyway leading to the flats where there is another door. At the moment the people get through the other door by knowing a key code what I want to do is to use the intercom so that the flats can speak to the people at the first door and decide let them in the using the same handsets using the exsisting door entry system for the inner door. Is it possible to add a second call station to release outer door and to piggy back onto the existing system ?
