Only had a telephone description of a fault. Would appreciate your thoughts.
A small cu has been installed, fed from the incoming tails of main cu, via Henley blocks (before main cu RCD)
This small cu is to power a EV charging point
Small Cu has a 30ma RCD feeding the charge point which has a built in RCD.
Now when the charge point is used, it trips the RCD, not in the small cu, but in the main cu.
Switching off the shed MCB on the main board stops the tripping.
