INterference with cables?
mo2
25 May 2006
Birmingham
hello, will I have any problems with interference if I run a bunch of speaker cables, a cat5 cable and a satellite cable in one bundle. Thanks
You will need to run cat 5 separately.
Normal cat 5 cable has to be run seperately from all other services
otherwise the transmission rate becomes degraded.
You can get double shielded cat 5 cable on which you can Earth the outer
shield, for noisy enviroments.
when you say degraded, will it be a significant amount?
is it possible to diy shield? If i dont, is 40cm of them being together going to cause significnant network speed problems
