Hi
New to the forums so firstly hello - stumbled open them whilst googling info on my new boiler . Looks like there are lots of helpful people / info here
I wonder if someone can help me with the following ....
I've just had a new intergas 36/30 combi fitted by a relative who is gas safe registered engineer so all good there . He's done it as a favour so I said I would sort out fitting the room stat as he's going on holiday and I'm more than capable of doing a bit of wiring ( worked in electronic test for 20 years). I have tools and a proper DVM etc . I just wanted to check exactly how I should wire it - I thought these room stats could now been powered via the boiler on a low voltage but it appears not ? The cm927 diagram just has a combi diagram example with reference to mains voltages .it looks as though it is simply a very fancy mains switch .
The boiler has 2 connectors x2 (24v) and x4 (230v) - is there a way for me to use the low voltage connector with 927? Bit confused !
Thanks in advance
Thanks in advance
