intergrated washing machine fit.
1 Nov 2010
Sussex
Im about to install a new kitchen with a intergrated washing machine. The problem is that the sinks cold and hot water plumbing run behind were the washing machine will go. is the washing machine goin to fit? ive looked at several different machines but they all are different sizes with no accurate depth measurements.
Can you either run the pipe work under the floorboards, which will erase any problem or run the pipes at a lower level 50mm-75mm from the floor.
Usually does the trick.
i wish i could, concrete floors. i wish manufacturers would be more clearer on there measurements :s
You make it fit.
You lower the pipework or you bury it in the wall or you use deeper worktop so it can sit in front, or you redesign the kitchen.
