I have been installing normal door linings,, they are about 132mm wide, but now I need to install two door linings on a cavity wall which is nominal 300mm thick, rather than 100mm of the internal walls.
I am not sure how to go about this. I am thinking the door lining will go over the one side of the cavity, as normal, then I will run a plasterboard on the reveals, just like we sometimes do for windows and external doors.
But looking at my current house here, it seems in a similar situation, they have used a very wide plank of timber to go over the whole cavity, and then fitted door architraves on both sides!
