Hello
One of my interior doors keeps springing open. It is engaging in the strike but only by 1.5mm. The tip of the latch has rounded off so I'm guessing it's not sufficiently engaged. Unfortunately the door frame looks to be concave at the latch (previous bodge maybe?)
Can you get a "long throw" latch which sticks out a bit further? Any other suggestions to avoid having to pack the hinges and then plane the door? The strike, hinges and latch plate are all flush to the appropriate wood surface.
bsr
bsr
