Having read the earlier post about float and set, which I dont quite grasp, could someone advise on the best way to finish the interior walls of my extension.
Most of the walls are thermal block, some are conc block, and some will be stud/plasterboard. There is also the previously painted, ex-external wall to deal with.
My plastering is fine on plasterboard walls and ceilings, but I've never actually done any rendering.
I had assumed to slap on a 6:1 sand/cement render onto all the thermal and concrete blocks, followed by a thin skim. Or am I missing something?
From what I remember seeing in my younger days, the render just gets slapped on, till a little firm, then scraped back with a feather edge to a flat surface, which can be skimmed the following day, or several days later.
There are lots of different walls to work on, so I can try my skills on a small section first. The biggest wall is 6m wide x 4.5m high. Think I'll leave that one till last!
Any advice or guidance much appreciated thanks.
