hi lads i have built a 40mm log cabin for the kids and want to paint the inside cream how long would you say matt emusion would last as eventlly ill be cladding it
Provided its weatherproof and relatively dry you'll probably get a couple of years.
I'm not sure about emulsioning straight onto the timber though, could end up with peeling and cracking. May be worth considering an acrylic primer as this will stick to the wood better and, being water-based will give you a good grip on the emulsion.
