I'm going to insulate my outside interior wall but need a bit of info regarding space! The insulation is going up the stairs and as such there is not a lot of room so need to keep the space i'm losing to a minimum. Can I just stick the poly plasterboard straight onto the wall using dry wall screws without battens to save room, if not how to I go about fitting them? Do I need to use metal battens then stick the board onto that plus the skim maybe losing 60mm? Doesn't sound ideal so help and tips much appriciated
Adam
Adam
