Given all the dire warnings about DIY boiler repairs I am rather loathe to raise the subject in case I am shot down in flames. But let me just say that I do know when I need to call in the experts and am quite happy to do so.
My query concerns a Myson Orion Fanfare boiler new in 1992.
Intermittently the main burner will fail to fire up. Often the scenario is that the boiler will fire up fine from cold, run for a while, then if it shuts down for any reasons and then the system call for heat again the boiler fails to fire up. The pilot light lights up with a good sized flame, I have just fitted a new spark ignition electrode, but the main burner fails to fire up. The fan, the pressure switch, the thermostats are all working fine and I have replaced these items over the years.
When the main boiler does fire up there is a full electrical feed measurable at the main burner gas valve contact, but when it fails to fire up, despite the pilot lighting up OK, there is no electric measurable at the main burner gas valve contact.
This indicates to me that it may be due to a faulty ignition circuit PCB. I do not mind whether I replace it or I get someone in, it is just they are expensive items and it would be nice to know if I have correctly pin pointed the problem. The more so as being an intermittent fault chances are that if I get someone in the boiler will decide to work fine on that occasion.
Any thoughts on this one?
Regards Steve
Regards Steve
