My girlfriend has just moved into a property with a 5 year old Worcester Bosch 28i Junior.
I noticed that the pressure was well below the red marker set at 1.5 bar so I filled it up. I noticed that when I topped it up it started dripping slowly from underneath the boiler. This eventually subsided after about 5 minutes so I though everything was ok.
However, it keeps losing pressure to the point the warning light comes on whereupon I have to top it up again. This happens after a couple of days use or sometimes longer i.e. it's not consistently losing pressure.
Having read a couple of threads on this I've checked to make sure there is no water coming from the pressure relief outlet which there is none but I haven't been able to watch it for 24 hours. Currently got a dry rag underneath and constantly checking to see if it's getting wet!
Yesterday, when I had to top it up again I noticed it was leaking a lot more than it normally did from underneath the boiler. I had a good look underneath and from what I can see it is leaking from the black plastic pipe that is attached to the bottom left of the pump. However, it may be dripping further up and splashing onto it. It was dripping fairly heavily (produced about half a cupfull of water) and then stopped.
It is now not leaking and, although the pressure when the CH was off has dropped half a bar since yesterday evening, now that the CH is on the pressure has gone up to the 1.5 bar marker.
I cannot spot any leakage around any of the rads or any damp patches elsewhere. It's a ground floor apartment BTW.
Am I right in thinking that to lose 1.5 bar of pressure would indicate a rather large leak? How much water would that constitute as, from what I've seen of the underside of the boiler leaking, there is not enough water coming out this way to justify that much of a pressure drop?
I've rang up WB and they charge a £210 callout but pay for all the parts and labour. I can also sign up for their yearly coverage of £289 over installments.
Having looked at the prices of the pressure release valves (£10 odd) and expansion cylinders (£70 odd), if it is those, then what should I do?
Should I just get a plumber to look at it as something tells me it should be someone well versed in WB boilers and their nuances? I'm also keen to get the cover off to see if I can work out exactly where the internal leak is coming from....
Any advice?
Dan
Any advice?
Dan
