- Joined
- 23 Mar 2021
- Messages
- 61
- Reaction score
- 1
- Country
Ongoing issues with boiler , I require a few answers to a few questions please , it would be great help , going through a process of elimination.
Heating seems ok , however water gets hot , runs hot for a few minutes then goes cold , then starts to get hot again . I've changed the thermo on the hot water pipe , didn't make a difference.
To help me narrow it down .
If the CH cuts out every now and then due to overheating in a similar way to the water ( I wouldn't necessarily realize it as boiler is in another room ) , if the CH thermo is faulty ( I didn't replace this once ) would CH cutting out effect Hot water also , would both cut out as a fail safe if the thermo on the other kicked in ?
Thought might be worth changing CH thermo if this is a possibility .
Second question is would a faulty flow valve result in on off hot water or would it prevent water heating at all .
I knows it possibly heat exchanger , however I want to eliminate everything first.
