Hi all new to this forum so be gentle
i have a 8 year old Saunier Duval SD 30e (i believe its a rebadged Gloworm) combi boiler. a few years back i used to have a similar problem. in the morning we used to get HW then just cold water
by the way CH works fine at all times.
Brit Gas arrgh eventually found the problem after 5 visits, i believe the changed the diaphram for HW.
a similar problem i have now is i dont get HW until i 'reset' by pressing the boiler lock out i first have to press to summer setting then the red light appears 'boiler lock out' once i reset this the HW works for a while, then have to repeat the process if we require HW.
i hope i make sense?
does this sound like the same issue? in the installing and servicing manual it says i would need to drain the boiler to change the diaphram,
thanks in advance
thanks in advance
