Intermittent ignition spark on Bosch gas cooker
30 Mar 2022
Hi all - any ideas appreciated.
I have 2 rings where the spark is intermittent and I need to use a lighter to get them to catch light. Then they work later on that day, then not, then they do work.
Really can't live with it.
Any ideas appreciated
I have the same issue, 2 of the rings stopped sparking entirely.
Heard from the previous tenant that this had happened before, usually after food spilling onto the stove or the like. They suggested cleaning the sparkplugs would help.
I gave the whole stovetop a good cleanup, and it seems to have worked to an extent. Now the two rings spark a bit more like normal, although still intermittently skipping a few sparks.
I haven’t wrapped my head around why the two of them seem to be tied together, and whether grime getting into the system is causing a block vs a short.
Since I originally posted , I did a lot of searching and reading. I applied superglue to the ceramic part of the sparker, let it set, and ....no improvement.
Bizarrely , I find that the first light of the day is hard and needs a hand with a BBQ lighter, then most of the rest of the day, it eventually lights after a couple of attempts.
But, it's still annoying me , but not enough to spend lots of £'s getting new ignition etc
Which suggests moisture or condensation shorting out the high voltage ignition system.
But wouldn't that sort itself out after a few days, as the moisture would be burnt off after a few mins? We don't have pans boiling over with any regularity, maybe once a month on one ring at most.
So a really thorough clean with wire wool or something 'softer' ?
Just clean and dry plus maybe check under the panel where the ignition unit is, to make sure all the HV wiring is clean. For my hob, it is really simple. You just lift the grids off, the burners and the control knobs, then the nuts onto which the grids locate, bolt the panel to the frame below. Isolate the power, before your start.
Thanks for that tip(y)
